Ansys Learning Forum Forums Discuss Simulation General Mechanical difference between nodal displacement and displacement Reply To: difference between nodal displacement and displacement
ErKo
Hi
A fixed support on a beam should give a DX=DY=DZ=ROTX=ROTT=ROTZ =0, so all degrees of freedom for a beam node equal 0.
With nodal displacements you can set the the translational degrees of freedom (DX,DY,DZ) as needed to a value (DX=value,...).
Hope this explains everything
Erik
