Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Compare between Volume Flow Rate and calculation with Simpson 1/3 rule. › Reply To: Compare between Volume Flow Rate and calculation with Simpson 1/3 rule.
July 29, 2021 at 6:51 am
Amine Ben Hadj Ali
Pretty much related as Rob mentioned to interpolation of the values to the line you created. I will be good to plot the lines in yellow colors on the last mesh picture you shared.
