Ansys Learning Forum Forums Discuss Simulation Fluids Compare between Volume Flow Rate and calculation with Simpson 1/3 rule. Reply To: Compare between Volume Flow Rate and calculation with Simpson 1/3 rule.
Pretty much. Double the resolution (use adaption) and try again.
