Ansys Learning Forum Forums Discuss Simulation Fluids Compare between Volume Flow Rate and calculation with Simpson 1/3 rule. Reply To: Compare between Volume Flow Rate and calculation with Simpson 1/3 rule.
Makara
I use X=0 with The cell centered value the same as Node Value. I just change the location of it only.
