Ansys Learning Forum Forums Discuss Simulation Fluids Compare between Volume Flow Rate and calculation with Simpson 1/3 rule. Reply To: Compare between Volume Flow Rate and calculation with Simpson 1/3 rule.
Makara
The Mesh that I use with 10 Vertical Mesh. So this mean that the Cell Center is interpolation from the Node? Or Somethings?
Thanks.
K. Makara
