Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Compare between Volume Flow Rate and calculation with Simpson 1/3 rule. › Reply To: Compare between Volume Flow Rate and calculation with Simpson 1/3 rule.
The values are usually fairly similar if the mesh is well refined. How different are the positions and x-velocity?
