Ansys Learning Forum Forums Discuss Simulation Fluids Compare between Volume Flow Rate and calculation with Simpson 1/3 rule. Reply To: Compare between Volume Flow Rate and calculation with Simpson 1/3 rule.
Makara
Hello Sir
I have one more question about my 2D problem that I try to export X-velocity solution data using ASCII file type that I already create the node point. when I export using Cell center and node the result is much difference so how ANSYS calculate the Cell Center X-velocity in 2D? How can I convert Node to Cell Center?
Thanks
Best Regards
K. Makara
