Ansys Learning Forum Forums Discuss Simulation 3D Design How do I save the data in Table of design Points Reply To: How do I save the data in Table of design Points
Dragana Jandric
You can try to export to csv file if you do right mouse click on the table of Design Points. You can also do copy/paste from the table of DPs to Excel.
You can't import outputs, you can copy/paste inputs from the excel or csv file into table of DPs but WB needs to run the model to populate the outputs. This should work in v19.2. I am running 2021R1.
