Ansys Learning Forum Forums Discuss Simulation Fluids Gray band scattering coefficient Reply To: Gray band scattering coefficient
Jayda
Hi SD Yes, I did. But I want the scattering coefficient to be identified per band, as I do with the absorption coefficient (via DEFINE_GRAY_BAND_ABS_COEFF). I know how to define a UDF of the class DEFINE_PROPERTY. The issue is that via DEFINE_PROPERTY there cannot be a scattering coefficient that is different in different light wavelight bands.
Why is this not possible for the scattering coefficient? And is there a way around? Thanks!
Kind regards
Jayda
