Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ACT-Moving heat flux plug-in parameter setting problem › Reply To: ACT-Moving heat flux plug-in parameter setting problem
Aniket Chavan
Hi Ace The extensions on the Ansys App store, come as is, with no support as per the clickwrap agreement that you agree to while downloading it. This could be due to functional limitations that this limit has been forced in the app. Fortunately, you can take a look at the source code that is included with the app to check the reason or to modify it to suit your needs!
-Aniket
