Ansys Learning Forum Forums Discuss Simulation General Mechanical How to set the maximum eigenvalue real extracted as a parameter in a modal analysis using APDL? Reply To: How to set the maximum eigenvalue real extracted as a parameter in a modal analysis using APDL?
dlooman
You can use *get,,MODE,N,... as shown below for frequency and stability values. You can use *get,,active,,set,nset to retrieve the number of sets on the results file
