Ansys Learning Forum › Forums › Discuss Simulation › Fluids › How to create the particles bed from coordinates and radii in Selective Laser Melting? › Reply To: How to create the particles bed from coordinates and radii in Selective Laser Melting?
Dubey92
Thanks for your reply. My spherical particles are not smaller than the cell size.
As in this figure, I have used "Cell Registers>New Region>Hexahedral" first to create a region with the metal block dimensions and then used patch to assign it the metal volume fraction.
My question is how to patch the metal volume fraction in a similar manner to a large number of spherical particles(I have the coordinates and radii) above the lower metal block?
As you suggested earlier, should I create a journal file to read the particles coordinate and radii from my data file and then use patch for the same? Is this the way to use a journal file?
