Ansys Learning Forum Forums Discuss Simulation Fluids How to create the particles bed from coordinates and radii in Selective Laser Melting? Reply To: How to create the particles bed from coordinates and radii in Selective Laser Melting?
I'd use a journal to create all of the registers, then manually patch the material into those registers. So you need to add the position data into the journal: Excel is a good tool for this as you can put the commands into cells & then copy the text file position data into that.
