Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › issues with rotation in mechanical + thermal › Reply To: issues with rotation in mechanical + thermal
st2021
Hi, thank you for your reply. It is a revolute joint. The body is flexible, not rigid. So I was hoping with rotation in one axis of rotation friction would still work: it would deform locally in whatever area the second block is touching.
I don't mind if there is no friction, but it is not supposed to cool down, is it? It is a simulation without coupling, only structural thermal.
