Ansys Learning Forum › Forums › Discuss Simulation › Fluids › ICFD_LEVELSET difficultyies › Reply To: ICFD_LEVELSET difficultyies
July 27, 2021 at 8:04 pm
Hello
To properly investigate this, we would need the full input file, but it's not permissible to pass that data through the Forum. However, there are two major points to consider:
1) You need a DYNA version which has type 2 - this is available only in a Release R13 but that has not yet been formally released - it should be released in a couple weeks.
2) You need to have a least one ICFD_PART which has void material assigned to it and one which has fluid assigned to it.
Please check that and look for the imminent release of R13.
ref: 2021071410000082
