Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Distributed Moment Load › Reply To: Distributed Moment Load
erik.kostson
Hi
There is not a command to do this (moment/unit length load) - most likely you need to loop over the nodes and apply a nodal moment with the moment needed at that point (done via the F command and using MX,MY moment labels - see F command for more details in our help manual).
Thank you
Erik
