Ansys Learning Forum Forums Discuss Simulation General Mechanical Bolt preload and fatigue analysis using Ncode Reply To: Bolt preload and fatigue analysis using Ncode
Dragana Jandric
You will not be able to pass stress combinations from Mechanical to nCode. nCode has duty cycles under load mapping for the load step combinations. You can read more about it in the nCode help and there are also examples in the nCode practice guide. Here are few slides to get you started.
