Ansys Learning Forum Forums Discuss Simulation Fluids Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
Jason Sum
Now that the residual convergence and mass imbalance were deduced to be reasonable, for checking the velocity or other variable, should I plot to monitor them just like monitoring mass imbalance, OR just observe their range in cell register? Thanks!
