Ansys Learning Forum Forums Discuss Simulation Fluids Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
On your machine, with a suitable licence, 6 would be the maximum. Depending on the cpu and boards you should see good (near enough linear) speed up. To give you an idea KAUST ran on 200k cores a couple of years back: we run 2-300 cores regularly here.
