Ansys Learning Forum Forums Discuss Simulation Fluids Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
Jason Sum
Okay! I will try resolve the inflation parts.
By the way, how can I check the balance?
Also, now actual physical flow time merely = 200 x 4e-5 = 0.08s, which actually need wait for the computer to run for about 36 hours
In my case, what do you suggest so that the calculation can be way faster? (Like reduce meshing density or any other possible solution?) I am only having 6 core and GeForce GTX1650 4GB equipped. Thanks!!
