Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? › Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
Please post a couple of screen shots from the movie - I'm not permitted to open it.
If every time step is converging then there's a good chance the solution is reliable. However, you also need monitors of mass etc to confirm.
