Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)? › Reply To: Which solution method (scheme) should I select for multiphase flow (pumping gas to blow water out)?
Have a look to understand why they're skew: I'd not expect the mesher to struggle with the CFD settings in a pipe!
