Ansys Learning Forum › Forums › Discuss Simulation › Fluids › execution error for FENSAP /On the other hand no problem for Fluent › Reply To: execution error for FENSAP /On the other hand no problem for Fluent
July 26, 2021 at 5:12 pm
Jian Chen
hi,
Can you do the test as following:
after your fluent run successfully (let's say 1 or 2 iterations), save your fluent run as *.cas (or *.cas.h5), then import your fluent cas file into Fensap-Ice and try to run it again. See if this way works , and if this way gives any other error issue. (Please copy the error message to us if it appears.)
Thanks
Thanks
