Ansys Learning Forum › Forums › Discuss Simulation › Fluids › execution error for FENSAP /On the other hand no problem for Fluent › Reply To: execution error for FENSAP /On the other hand no problem for Fluent
July 25, 2021 at 7:03 pm
Hi
Is the video you shared your geometry? I don't see any sphere. Or is it something you followed to create your own geometry setup.
If its a cube (geometry) in a sphere (fluid), than that should not be a problem for FENSAP to run. What's the execution error you are getting ? It could be anything. Open out file (logs). And see what error is printed.
Also for the sphere how do you setup the boundary condition: As 1 Farfield or into 2 BCS: Inlet/Outlet ?
Thanks. Let me know. Cheers
