Ansys Learning Forum Forums Discuss Simulation Fluids Why previously updated DPs change status if another DP is updated opening Ansys software GUIs? Reply To: Why previously updated DPs change status if another DP is updated opening Ansys software GUIs?
fabio.dinatale
Thanks for your reply.
Part of the problem is the way the DPs are defined.
Does it exist a way to define the DPs that permits to avoid the problem?
If it could be useful for understanding a possible solution to the problem, this behavior (status change) does not occur if I simply update each component (i.e.notopening the GUI).
Regards Fabio
