Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Decimal point is changing when reopening a model. › Reply To: Decimal point is changing when reopening a model.
June 28, 2021 at 9:04 am
Just to be sure, could you run the simulation once (with the correct values) , save it, close it. Then reopen the model, clear generated data and evaluate results again. Now do you see a difference between results of the first and second run?
Regards Ishan.
Regards Ishan.
