Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Is it possible to apply a current to a moving conductor? › Reply To: Is it possible to apply a current to a moving conductor?
July 29, 2021 at 5:45 pm
There is a closed steel frame to fully cover the inner coil (plasma) in the geometry, so there is no entering for the current in both physics and geometry. We could not apply the current on the inner coil with motion in the real application if the geometry is correct.
Actually, Maxwell will follow the real physics, although it is just a FEA simulation. Thus, we could not apply the current on the inner coil for the existing model now.
Could you double check the geometry, what is the real excitation and how to enter the current for this rotating inner coil? Thanks.
HDLI
