Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › ERROR: Data file file.db does not exist for RESUME › Reply To: ERROR: Data file file.db does not exist for RESUME
April 11, 2022 at 2:11 pm
Dear
I had to investigate on this problem, because we use Harmonic Response linked to a Modal Analysis in many classroom examples and exercises -- was working for any previous year, but not this year. I found out that the same problem happens for any analysis that has its Results linked to the Setup of a second analysis. For instance, Results of Static Structural linked to the Setup of Buckling will lead to a similar error. The most frustrating observation in this problem is having a File Explorer Window showing the results files actually disappear when solving the second analysis.
It appears that when I SET THE LANGUAGE ON ENGLISH IN WORKBENCH, the problem disappears. Normally we would set the language to French (French University here).
We use Academic licences with 2021 R1
