Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Cannot calculate shape change due to wear in LS-DYNA › Reply To: Cannot calculate shape change due to wear in LS-DYNA
June 27, 2021 at 7:28 pm
Thank you ! It appears to work! I see the deformations.
One thing has happened however, I only see deformation on some of the parts, while there is non-zero wear depth and sliding distance on all the parts of the simulation I only got deformation on two of the parts.
