Ansys Learning Forum › Forums › Discuss Simulation › Fluids › At what temperature are unburnt mixture properties calculated in the non-adiabatic premixed model? › Reply To: At what temperature are unburnt mixture properties calculated in the non-adiabatic premixed model?
June 16, 2021 at 9:41 pm
Hello
The answer to your question depends on if you have checked the "Non-Adiabatic Laminar Flame Speed" option in the "Properties" tab. If yes, the properties will be calculated with the PDF calculator automatically and tabulated as a function of f and radiation loss. While if not checked, it will use the adiabatic properties directly. Thank you.
