Ansys Learning Forum Forums Discuss Simulation LS Dyna Pressure load is exerted in the x-direction instead of on the normal axis (LS-DYNA) ? Reply To: Pressure load is exerted in the x-direction instead of on the normal axis (LS-DYNA) ?
Akshay Maniyar
Hi @LCP I am not sure exactly why you are getting difference in the results for 19.2 and 2020R1. Can you create a new post for this query as the original question was for LS-Dyna. May be some structures expert can answer this. I will also check mean while.
regards amaniyar
