Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Large Eddy Simulation for oil-water stratified flow – Pressure signal problem › Reply To: Large Eddy Simulation for oil-water stratified flow – Pressure signal problem
peter_beshay
Dear Mr Rob At the inlet, i have already separate inlets for each phase. I don't get what you mean by separate?
Also, when i run Embedded LES, results are perfect. But when i run LES for the whole domain, i get these pressure bursts.
How can i dissipate turbulence at the interface?
Thank you so much for your help.
