Ansys Learning Forum Forums Discuss Simulation General Mechanical Simulating the bending/deforming of a flat, thin silicon layer into a spherical geometry Reply To: Simulating the bending/deforming of a flat, thin silicon layer into a spherical geometry
peteroznewman
Try contact with Keyop(12)=5. Make a small test model to confirm that this works the way you want.
The contact can be open at the start of the simulation, and as the pressure pushes the silicon chip down, the contact closes and holds the chip from that time onward.
Regards Peter
