Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Campbell diagram error › Reply To: Campbell diagram error
May 26, 2021 at 12:16 pm
file0.err
/COM,ANSYS RELEASE 2021 R1BUILD 21.1UP2020110916:33:01
*** WARNING ***CP =0.766TIME= 16:33:03
Element shape checking is currently inactive.Issue SHPP,ON or
SHPP,WARN to reactivate, if desired.
*** WARNING ***CP =0.812TIME= 16:33:03
Make sure that the rotating element component 1 (component name
CM_ROTVE) is axisymmetric about the axis of spin defined by the
CMOMEGA command to correctly account for the gyroscopic effect in the
stationary reference frame (CORIOLIS, ON,,, ON).
*** WARNING ***CP =59.453TIME= 16:33:53
Material number 11 (used by element 4141) should normally have at least
one MP or one TB type command associated with it.Output of energy by
material may not be available.
*** WARNING ***CP =65.594TIME= 16:33:58
*** WARNING ***CP =394.109TIME= 16:38:33
The number of frequencies is not the same for each load step.Make
sure the same number of modal solutions is obtained for each
rotational velocity.If it is the case but there are not always the
same number of complex frequencies with zero imaginary parts (zero
frequency), try using the Damped eigensolver (Method = DAMP on the
MODOPT command) with the negative frequencies option (keyNegFreq = ON
on the PRCAMP and PLCAMP commands).The PRCAMP command is ignored.
*** WARNING ***CP =394.609TIME= 16:38:34
*** ERROR ***CP =394.609TIME= 16:38:34
There are no data available related to the Campbell diagram.Please
issue the PLCAMP or PRCAMP command before issuing the *GET command.
This command is ignored.
