Ansys Learning Forum Forums Discuss Simulation General Mechanical Having Problem with XFEM while writing APDL commands in Ansys Workbench. Reply To: Having Problem with XFEM while writing APDL commands in Ansys Workbench.
Puhan
Hello
It has been some days and I could not find almost noting in this forum can anyone makes a discussion on this please, this has already been solved in APDL in Ansys manual I am just trying to replicate the same in Workbench as have to solve some other problems.
The whole problem is explained above. It is a three-point test. The below is the whole interface as you can see
The command is written is like following
"!Commands inserted into this file will be executed just prior to the ANSYS SOLVE command.
!These commands may supersede command settings set by Workbench.
!Active UNIT system in Workbench when this object was created:Metric (mm, t, N, s, mV, mA)
!NOTE:Any data that requires units (such as mass) is assumed to be in the consistent solver unit system.
!See Solving Units in the help system for more information.
/PREP7
!crack-growth criterion
tb, cgcr, 2, , , STTMAX ! Fracture Behavior: Maximum circumferential stress
tbdata, 1, 0.5 ! Maximum normal traction: = 0.5 N/mm2
!Decay of stresses on newly cracked interface
tb, cgcr, 2, , , RLIN
tbdata, 1, 0.04, , 0.0
! Element component required for XFENRICH command
esel,s,cent,x,-1,1
cm, testcmp, elem
allsel
! Define enrichment identification
xfenrich,ENRICH1,TESTCMP ! Defines parameters associated with crack propagation using XFEM
xfdata, ENRICH1, LSM, 939, 1042, 0.047123
xfdata, ENRICH1, LSM, 939, 1043, 0.047123
xfdata, ENRICH1, LSM, 939, 1045, -0.048062
xfdata, ENRICH1, LSM, 939, 1044, -0.048062
/com ******************************************
/com LISTING OF CRACK INFORMATION
xflist
! Crack-tip element
esel,s,elem,,939
cm, crktipelem, elem ! Element set component for CINT command
allsel,all
! Loading - Displacement on two nodes on top
nsel,s,loc, x, -0.048062, 0.047123
nsel,r,loc, y, 1.5
d, all, uy, -0.16 ! Uy = -0.16mm
d, all, ux, 0
allsel
/SOLU
! CINT calculations : Defines parameters associated with fracture parameter calculations
CINT, NEW, 1
CINT, CXFE, crktipelem ! Crack-tip element
CINT, TYPE, STTMAX ! Uses STTMAX
CINT, RSWEEP, 181, -90, 90
! CGROW calculations : Defines crack-growth information
CGROW, NEW, 1
CGROW, CID, 1
CGROW, METHOD, XFEM ! Uses XFEM method for the crack propagation
CGROW, FCOPTION, MTAB, 2 ! Fracture criterion
SOLVE
finish"
So kindly please let me know, I will be grateful to you.
Can you sir please look into it? Thank you very much.
