Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Core Loss Hysteresis Model › Reply To: Core Loss Hysteresis Model
May 3, 2021 at 11:40 am
Hello
Make sure you have set core loss for the required geometry using Maxwell 3D --> Excitation -> set core loss and selected the geometry. Also make sure you have imported the correct graphs in the material definition. May be you can use Power Ferrite core loss model and import the P_loss vs B at different frequencies provided by the datasheet of material and also its BH curve to get the results. There is a possibility that you have not assigned a material to object Rectangle1.
