Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › it says FAILED MESH › Reply To: it says FAILED MESH
May 1, 2021 at 3:47 pm
Cn you post the image showing the problematic geometry and the mesh type used. However, based on the your query it is something to do with the geometry used might have small features such as cuts, fillets, chamfers or drafts etc. Try disabling the adaptive mesh and use smaller mesh size. But better suggestions can be made only if you able to post the problem.
Cheers, Ram
Cheers, Ram
