Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Applying rotor skew › Reply To: Applying rotor skew
NathanEmery1
Hi Navya, nnThank you for this post, I have also been using the Skew model for a PMSM in Maxwell. nIs there a way to apply a V-skew technique where the segment settings are not distributed from + to - degrees. nFor example if I want to apply a V-skew with +2.5 deg, 0 deg and +2.5 deg segments is this possible using the ansys Skew settings? nnPlease let me know. nThank you, nNathann
