Ansys Learning Forum Forums Discuss Simulation Preprocessing Face Meshing Doesn’t Work On A Simple 2D Narrowing Pipe Reply To: Face Meshing Doesn’t Work On A Simple 2D Narrowing Pipe
simsek8
Thank you very much. I figured out except one thing. There is a pop-up message that says:
'The specified defeaturing tolerance was found to be larger than a specified size. The elements on one or more edges may be defeatured out.'
