Ansys Learning Forum › Forums › Discuss Simulation › Preprocessing › Face Meshing Doesn’t Work On A Simple 2D Narrowing Pipe › Reply To: Face Meshing Doesn’t Work On A Simple 2D Narrowing Pipe
peteroznewman
In DesignModeler, add new horizontal plane through the top of the narrow section. Rotate it so the Z axis points up then slice all bodies to get 5 bodies in one part. Face meshing will then give you what you want.
