Ansys Learning Forum Forums Discuss Simulation LS Dyna (LS-DYNA) error:Pyramid elements have been detected.How to solve it? Reply To: (LS-DYNA) error:Pyramid elements have been detected.How to solve it?
panlicheng
For the meshing error, can you all tet mesh, see if it goes away, for the second error message, can you open the file named messag, see what is the exact LsDyna error message is?/forum/discussion/comment/113485#Comment_113485
@mji, nThank you for your answer.Tet mesh dosen't work. The second error is :nAnd my problem now is that I used the default setting to solve the problem,although the result is incorrect.I want to encrypt the grid to get the right result but failed, there will be an error, and now the default grid can't solve the problem.I don't know how to mesh.n
