Ansys Learning Forum Forums Discuss Simulation Fluids Error: Flow boundary zone found adjacent to solid zone Reply To: Error: Flow boundary zone found adjacent to solid zone
syed123
Hi Rob,nnThe material density is not pressure dependent so i have left the outlet pressure = 0. nWhen Run the simulation i get this result:nnThis does not look right compared to other simulation that were run (The contour plane is at the cross-section of the Nacelle). Surely the pressure should increase towards the fan area and the walls of the Turbofan. Do you think this may be a boundary condition problem or a mesh problem or somthing else that i am not aware of.Regardsn
