Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Effect of Momentum equation spatial discretization scheme on the solution › Reply To: Effect of Momentum equation spatial discretization scheme on the solution
YasserSelima
This is converged solution. You have residuals converging and reaching constant value. The monitored value reached steady state.nThe reason you are not getting lower residuals could be the nature of the problem. When you try steady simulation of a case that is unsteady by nature.nn
