Ansys Learning Forum Forums Discuss Simulation Fluids How to select an area as a body Reply To: How to select an area as a body
zedstomper
Select faces and give named selection to faces. Use face filter to select faces. Then select bodies and give named selection to bodies. Use body filter to select bodies. https://us.v-cdn.net/6032193/uploads/9L20DZ27AYNU/image.pnghttps://us.v-cdn.net/6032193/uploads/EX0OZPDIR77R/image.pngRegards,KeyurHow to access Ansys Online Help DocumentHow to show full resolution imageGuidelines on the Student CommunityHow to use Google to search within Ansys Student Community/forum/discussion/comment/108982#Comment_108982
nThank you for the reply. If by box select filter you mean the box select button at the top anytime I choose that the only object I can select is the whole tank or peices of the impellar. Nothing else. And we need the rotational zone selected.n
