Ansys Learning Forum Forums Discuss Simulation Preprocessing Generating mesh for a foam Reply To: Generating mesh for a foam
ramgopisetti
Can i know what solver are you employing to model the foam body, by that i mean, if you are familar with the LSDYNA -FOAM material MAT_005/MAT_SOIL_AND_FOAM, you dont need to model the microstructure of it, you can use the Experimental data which has followign information apart from isotropic eleasticity terms as follows n2) if your aim was to describe the microstructure deforming mechanisms, your approachs is good, that said, if you want to refine the mesh, it will take some CPU time and its an tie off between fedility and time. nCheers,nRam n
