Ansys Learning Forum Forums Discuss Simulation General Mechanical Problem in ANSYS Static structural Simulation Reply To: Problem in ANSYS Static structural Simulation
peteroznewman
nI read the paper you kindly provided. They used Beam elements and Shell elements. That means you need curves and surfaces. STOP MAKING SOLIDS!nYou have Sketch4, the Path. Don't sweep a profile. Export just Sketch4 as an IGES file. Import that into SpaceClaim. In SpaceClaim, define a Circular Beam Profile and edit the profile to assign the correct radius for the braid. This is one of the tricky aspects of using SpaceClaim. Watch a YouTube video on how to do that. Use that Beam Profile and create beams using the imported path curves.nSpaceClaim can create an edge at the intersection of two surfaces. Create a cylinder and plane surface, then use Project to create the edge curve you see in the image. Use the Select tool to select that edge, then Ctrl-C and Ctrl-V to copy the edge and paste it as a Curve. If the export/import of Sketch4 fails for some reason, you can create the 3D curve from the surfaces in SpaceClaim.n
