Ansys Learning Forum Forums Discuss Simulation Electronics Tabulating Mag E Field Reply To: Tabulating Mag E Field
rtk
,nUsually, the fields can be exported from Ansys HFSS in the below ways:nPlot 2D contour plot by specifying the geometry/object and the quantity - so you will get a flattened Mag_E or Mag_H plot - then export it as '.csv' format.nThrough 'Compute max parameters' (from Project Manager - Radiation) you can get the field exported in .csv formatnnHope this addressed your concern.nnRegards,n
