Ansys Learning Forum Forums Discuss Simulation Electronics I am planning to analyse the design of High Frequency Transformer in Ansys Maxwell Transients. Reply To: I am planning to analyse the design of High Frequency Transformer in Ansys Maxwell Transients.
Sherin
I changed step time small value than entered above and got high frequency input signal. Thanks for the help.nI changed the coil assembly as foil type winding with two turns and terminal connection as shown below.nGiven input voltage at any specific instant (at wt=90) then entered Va=325V, Vb =-162V and Vc=-162V. It worked and flux density distribution found as uniform, but input current taken from the source is in kilo amperes. Normally in open circuit condition current requirement is less, but how my assembly takes kA of current??? (Transformer rating is 1000kVA, 11kV/415V)n
