Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Original Fluent simulation’s output files deleted when re-initializing duplicate simulation › Reply To: Original Fluent simulation’s output files deleted when re-initializing duplicate simulation
karthik.remella
Administrator
Hi,nCould you please double-check the location of the UDF file? Is the duplicate instance of Fluent reading the UDF from the original case file directory? Also, make sure your duplicate simulation is reading the UDF from its corresponding working directory. Please try to enforce this (if you are already not doing this).nKarthikn
