Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to model material deposition in ANSYS APDL? › Reply To: How to model material deposition in ANSYS APDL?
February 4, 2021 at 7:58 pm
I'm quite certain that all elements (active or not) should be selected prior to every SOLVE you do, so Dave's suggestion is probably a good one. I don't think you have to remove HFLUX loads from faces of deactivated elements - it looks like the code does that automatically and internally for you:nn
n
n
